  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
How do you Scale a Symbol within a Tabular Note in NX drafting
zizacad
Automotive
Jun 17, 2014
17
0
0
BR
thread561-317320
Hi Everyone!
My name is Sergio.
I saw that in a old thread
( The attached PowerPoint explains the situation better but here goes...
I want to add a symbol to a cell within a "Tabular Note" in NX 7 drafting. I can add the symbol with an attribute call-out but I cannot scale the symbol. I know there is a scale symbol setting but it seems to have no effect. This same idea applied to a "Note" scales perfectly fine.
The attribute that I want to add is:
<W@$SH_SHEET_PROJECTION_ANGLE>
Does anyone know how to scale the symbol in a "tabular note"? )
Im working in NX 1953.
Anyone here knows if its already get a solution in nowdays?
Thanks in advance!
Sérgio Luiz - Designer_CAD
I tried to figure this one out, but I do not have an answer for you.
I even tried scaling with TRANSFORM but it does not work.
Jerry J.
UGV5-NX1961
Thank you Jerry, but what I need is to put it inside a title block e keep it working automatic.
This is a question whether this company ever uses first AND/OR third projection on their drawings ,
or if they only use one of these methods.
If they use a single method, they can smash the symbol or draw a symbol of their own. No need for automatic change.
If they use both methods and want the symbol to automatically swap, they are stuck.
Tomas
Never try to teach a pig to sing. I wastes your time and it annoys the pig.:)
When you work for many of companies around the world it's become very important using automatic changes, it avoid any forget about it.
