How lubrication takes place in muff coupling ?
I think this is used on ship. Is it right ?
When the coupling is in the position the outer sleeve is hydraulically driven on the inner sleeve.For that ,oil is supplied at 200 bar oil at two points for forced lubrication and at 300 bar oil for driving the outer sleeve.
Muff coupling
When the outer sleeve reaches at required position the forced lubrication pressure is released and drained.Now hoses are disconnected and plugs are fitted.
Muff coupling
