Long Cloud
Computer
To add murphree efficiency to column IO method, I modify the triangle dialog matrix, and calculate K in outside by bubble point, not by TPXY. when I converged the outside and re-calculate the the inner variable, such as Sb, I found the Sb is changed. So the column results is not stable. Anyone can give any suggestion?
C#:
private void CalcLvByV_MurphreeEff()
double[,] Vij = new double[info.NumComp, info.NumStage];
double[] Rl = (double[])info.Rl.Clone();
double[] Rv = (double[])info.Rv.Clone();
for (int i = 0; i < info.NumComp; i++)
if (info.Zm[i] < info.MinZ || (info.IsWaterColumn && i == info.WaterIndex))
continue;
double[,] matrix = new double[info.NumStage, info.NumStage];
double[] arrFi = new double[info.NumStage];
double[] alphaSj = new double[info.NumStage];
double[] effTerm = new double[info.NumStage];
for (int j = 0; j < info.NumStage; j++)
alphaSj[j] = 1 / (info.Eff[i, j] * info.Alpha[i, j] * info.Sb * info.Sr[j]);
effTerm[j] = (1 - info.Eff[i, j]) * alphaSj[j] / Rv[j];
for (int j = 0; j < info.NumMainStage; j++)
if (j > 0 && !info.TotalPaFromTray[j - 1])
matrix[j, j - 1] += alphaSj[j - 1];
if (j == 0 && info.IsTotalCondenser)
matrix[j, j] += -Rl[j] * alphaSj[j] - Rv[j];
else
if (j > 0)
matrix[j, j] += -effTerm[j - 1];
if (j < info.NumMainStage - 1)
matrix[j, j + 1] += 1 + Rl[j] * effTerm[j];
arrFi[j] = -info.F[j] * info.Z[i, j];
if (info.WaterIndex == i)
arrFi[j] += info.Water[j];
double[] Vi = matrixCalc.Calc(matrix, arrFi);
if (Vi[j] < 0)
Vi[j] = 0;
clip(Vi);
Vij.SetRow(i, Vi);
double[] Li = new double[info.NumStage];
if (j < info.NumStage - 1)
Li[j] = Vi[j] * alphaSj[j] - effTerm[j] * Vi[j + 1];
else
Li[j] = Vi[j] * alphaSj[j];
if (Li[j] < 0)
Li[j] = 0;
info.Li.SetRow(i, Li);
if (Vij[i, j] < 0)
info.LstMessage.Add($"comp {i} in tray {j} is negative");
return;
if (double.IsNaN(Vij[i, j]) || double.IsInfinity(Vij[i, j]))
return;
info.Vi = Vij;
info.V[j] = 0;
info.V[j] += info.Vi[i, j];
info.L[j] = 0;
info.L[j] += info.Li[i, j];
if (info.Li[i, j] < 0)
info.Li[i, j] = 0;
if (info.Vi[i, j] < 0)
info.Vi[i, j] = 0;
