andradesilva
Materials
Hi all,
I have a set of CAD components added onto an assembly. I would like to do the 2D drawings.
However, I would like to adjust the dimensions between the components before I go to assembly environment.
Also, in 2D drawing, I am facing troubles adding dimensions (driven). I think it's because the box of some components are overlayed on adjacent ones.
So, the following two question arose from the problems described below:
1)How can I adjust the distance between components of an assembly composed by several copies of the same component?
2)How can I add driven dimensions to a 2D drawing composed by several copies of the same components
I don't have much experience in CAD with Solidworks, but I need to learn some stuff for this industrial project I am working at the moment.
Thanks in advance,
AndradeSilva
Thanks in advance,
AndradeSilva
