Hello everyone,
I have to apply displacement rate as 1 mm/minute and total displacement should be up to 10 mm? can someone help me with the boundary condition to be used in ABAQUS?
Thank You.
It would be really great if you could explain lil bit considering my case (1mm/min displacement rate and 10mm displacement).
Because I tried doing that but did not work may be because of wrong input.
Also in case of using amplitude what shall I provide in the step module time increment?
