frogcobbler5
Student
- Feb 16, 2025
- 1
Hello - I’m wanting to determine bending moment for a “+” shaped frame made from square tubing with a point load in the center in order to determine material sizing.
For example, for a 4’ simply supported beam with a 5-ton point load in the center, the bending moment would be (10,000lb*4ft)/4=10kip-ft, and you would choose a size of square tubing accordingly based on available flexural strength.
How does this calculation change when you weld a couple of 2’ pieces perpendicular to that piece to make a “+” shape?
