How to calculate curve for high viscosity liquid 22000cP viscosity chocolate syrup to be run?
pump_guy
IN
Hi All,
I have test results of a centrifugal pump run with water as fluid medium. However actual liquid to be pumped is Chocolate syrup with viscosity of 22000cP. So how do I account for high viscosity for converting water test results to high viscosity? I would appreciate your help.
Thanks so much!
Really don't think centrifugal pumps work at that viscosity. Figure I've heard before now is max 600cP.
High viscosity like that needs PD pumps like gear pumps or screw maybe.
What he said.
Consider this handbook from KSB.
Note: Your product might be out of the chart.
Better to consider a gear pump Stainless steel, typically in use in the food industry.
A google search will show you many brands. Keys words gear pump chocolate syrup.
Good luck
Pierre
I wouldn't use a centrifugal for that. Desmi, for one example, have a chocolate-specific gear pump; I'd look at something along that line, or a PC pump.
Is the syrup a Newtonian fluid?
How shear sensitive is it? (will high shear change its look or texture)
I have seen gear pumps, peristaltic pumps, progressive cavity pumps, AODD pumps, and disc pumps used for high visc fluids.
@Edstainless
Thank you all for your responses.
Yes disc pump will be used my apologies for mentioning Centrifugal pump. Do you have idea how disc pumps work?
Can we apply viscosity correction factor to Disc pump developed by HI for centrifugal pump?
Interesting.
disc pumps seem to be specially suited to very high viscosity low shear fluids / slurrys, etc.
e.g.
Essentially the discs whirl around, with or without slight ridges on them and use laminar flow / viscous drag to create flow from the centre to the outside. Some look like a centrifugal pump but without the impellors and just the discs.
Given that they work differently and with different fluids to those normally seen in centrifugal pumps, the answer is no IMHO. This level of viscosity is way above the limits of any correction factor.
I can't understand why you're not asking the vendors this question?
Best advice so far is from LittleInch contact the pump vendor. You could have had an answer by now.
