How to calculate required wall thickness for square duct
CobusvanJ
45
Can anyone point me in the right direction on how to calculate the thickness required due to pressure for a square duct. Pressure is extremely low, 5kPa/-2kPa. We need to add nozzles to it so I just have to make sure that the reinforcement calcs are done correctly.
Putting a nozzle in the flat side of a square duct isn't something which is covered by any code rules.
I think it would be possible to develop a hand calc from fundamental principles. Otherwise a more in-depth analysis is required.
Any thickness calc at that pressure (50 mbar) will give you fractions of a mm. Structural issues will predominate.
Most "ducts" are very thin sheet steel, but people make connections for them surely.
If you add as much steel as you're removing from the hole immeadaitely around the hole you cut out you're half way there.
See:
1)International Mechanical Code Chapter 5
2)NFPA National Fuel Gas Code
3)UL 1738 Standard for Safety Venting Systems...
And how not to: ASME Sec VIII Div 1, Apx 13 :)
Mike
