How to change edge color of a Body? 1
Lea75
51
ES
Hello everybody.
I need to change the color of the edges of one body in CatPart.
I was able to change the filling of it to black with: oVisproperties.SetRealColor 0, 0, 0, 0
But now I need to change the edges to white.
I looked for it everyware but I had no luck.
Is it possible?
Thank you in advance for any tip.
how about this:
Code:
oVisproperties.SetRealColor 255, 255, 255, 0
Not sure I understand your problem but White's RGB values are 255,255,255.
Calin
This is my code to set the filling of the main Body to black:
Set oSelection = CATIA.ActiveDocument.Selection
oSelection.Add oPartDocument.Part.Bodies.Item(1)
Set oVisproperties = oSelection.VisProperties
I already know that 255,255,255 is the RGB for white, but
which should be the code for changing the color of lines (edges) of the main Body?
Any suggestion about this?
I'm still stucked on this.
Hi.
With Selection you basically do things just like you would do them by hand. That is you have to select edges before setting color. It can easily be done with Search:
oSelection.Search "CATTopology.CGMEdge,sel"
oSelection.VisProperties.SetRealColor 255, 255, 255, 0
