How to create a DXF saving automation (by macro, by journal)
Pjone kenobi
FR
my target: my user will clic on a button which will launch a vb program or journal program
What the program should do:
* Correct solution: The program only will open the SAVE AS window and propose to the user to Save As his file with the DXF option correctly adjusted. The user must fill the name and /or the filepath and click on OK.
* Top solution: The program must save as the file in the DXF format, with the same filename, at the same filepath of the part
In advance thanks for your help!
Best regards
Here You can find journal for Your second question:
Link
With best regards
Michael
Perfect! I will try to adapt it.
Thanks a lot for your help.
Have a great day
