I've got a requirement to crimp to a spiral heating wire. It's a NiChrome resistance heating element, which is wound as a spiral around a core of glass fibers. It's covered with a layer of foam rubber like insulation, and then with a woven fiberglass covering. My understanding is that NiChrome is usually crimped for connections. I want to crimp a section of normal wire to the ends of the heating element.
For testing, I've been pushing back the outer woven insulation, then cutting the foamy insulation with a stripper. That allows me to spin or "unthread" the foamy insulation from the spiral. The NiChrome spiral is pretty thin, something like 28-30 AWG, I've been putting it into a standard butt crimp barrel with the 16 AWG extension and crimping both together. Then I can push the woven insulation over the crimp. I'd like to find something quicker and easier to do, as well as something that gives a better strain relief. I'm not convinced having the inner flex/strength member in the crimp is a good idea.
Can anyone give me any tips on a better crimp method?
