How to deionize tap water at low cost?
Avcifa
Marine/Ocean
May 2, 2021
Hello everyone,
I’m looking forward to find a cheap and small size solution to deionize untreated tap water. I’ll need between 500ml and 1L at each time. So very small scale.
Targeted measurements;
5.80 pH, 20 conductivity, 0 hardness
I appreciate your help if you can help me out.
I found standard household water treatment systems which are usually bigger than I need.
I need something smaller and more compact if possible.
