Hi
I have a PV design as per ASME Section VIII Div.1 with a shell and head thickness of 23.7 mm. Nozzles attached to the shell are 24-inch manhole, and others nozzle is 6, 3, and 2-inch. Meanwhile, the 6-inch inlet nozzle is attached to the head. Design temperature/pressure is 100 Degrees Celsius / 4.14 MPa
How to determine whether a nozzle needs reinforcement or not?
