irpheus
- Feb 15, 2009
- 34
... I am a bit unsure of whether or not this is the subforum to post this thread - if not I'd appreciate if you let me know ...
Hello everyone ;-)
I have for some time now been trying to find a solution for rapid etching of tracks (1-6 mm width) in very thin aluminum (<3um thickness) that is fused to a thin mylar membrane. Rapid etching means that a maximum of 1 minute is allowed for the etching process (less time is better).
The tracks may either be covered mechanically with a mechanical structure so that the etchant cannot get into the area of the tracks - or they are covered with a PCB resist that is commonly used in PCB manufacturing.
The PCB resist is normally removed using an NaOH or similar substance so using NaOH to do the etching will not work as it dissolves the PCB resist ...
To do the etching I have tried kitchen salt in water as part of an electrolytic process, however, this tends to take too long (the aluminum releases from the mylar) and does not entirely remove the aluminum ... small flakes of aluminum remains which is not acceptable in this context.
I have also tried a combination of HCL & vinegar, yet again it takes too long. The temperature of this solution was ~ 20 degr. C.
So, by posting here, I hope one of you know of a rapid etching solution for etching such a thin layer of aluminum... Please note additionally that the etchant needs be very reasonably non-harmful to both the environment (when released in very low amounts), the building where the etching takes place, and, not least, to myself.
I hope there may be a way of doing this and would much appreciate your feedback.
Cheers,
Jesper M
Hello everyone ;-)
Cheers,
Jesper M
