How to exclude a region from a Finite Element Analysis? 1
LeonardoArantes
Materials
Feb 14, 2024
Hi, I do use CATIA V5 Advanced Meshing workbench to mesh the part however I need to remove a region because it evaluates not accurate results due to rigid coupling...
Is there any way to ignore these values when plotting the results?
I've attached a screenshot indicating the area I need to "ignore", it is between the inner and the outer circle.
 https://files.engineering.com/getfile.aspx?folder=3cfdc51d-8c77-4244-b516-0d0d13c2184b&file=Captura_de_tela_2024-02-14_105730.png
Usually, color scale adjustment is sufficient to hide too high stresses and make the lower ones more visible. Most postprocessors allow you to do that by just specifying a custom upper limit.
