How to export a custom user command in NX 12
blaze10
Computer
IN
I have created a custom user command for Journal in NX 12.
I want to export this user command and its related files, which later on will be imported on other NX clients.
This exported file should contain the button name, icon and its Journal.
I have checked File tab→Export→User Defined Feature and working through the UDF wizard, but no luck.
How can I achieve this?
Thank you in advance.
The User Defined Feature (UDF) creates a modeling feature and is not directly related to journals and buttons.
If you have used the "customize" command to add your journal to your computer, you will need to find and copy those files to each other computer that you want to customize. Alternately, if you have a network location for your NX startup files, you can use "menuScript" to create new commands and push them out to every NX user.
www.nxjournaling.com
