how to export mass of an ANSYS Workbench model to a text file
andradesilva
Materials
PT
Hi all,
I am doing a static simulation on ANSYS Workbench 18.1 as a part of my work as a R&D Engineer.
I am trying to export the total mass of a model to a text file. If it is possible to obtain the mass of each element of the mesh, and export it, it would be better.
I am inserting an APDL code after solution (/POST1) that I am attaching in a text file. It is a partial element solution that allows to obtain the mass of the full model. It worked for me before in ANSYS MECHANICAL APDL, but I don't have so much experience in ANSYS Workbench,
Any help appreciated,
Thanks in advance,
Best regards,
Andrade Silva
 https://files.engineering.com/getfile.aspx?folder=c418b7e9-3541-41fc-9c58-c7d308b23de4&file=code_mass.txt
andradesilva
Check this thread-thread569-365593
Easiest way to get mass component/body wise is click on geometry ==> click on worksheet
I have slightly modified your code. Check out. Before solving uncheck distributed ansys option in solve process settings. PSOLVE command is not supported by distibuted ansys.
Code:
/POST1
fini
/sol
/uis,msgpop,3
irlf,-1
psolve,elform
psolve,elprep
irlist
fini
FINISH
*DIM,valuem,,1,1
*get,mtot,elem,,mtot,y
*VFILL,valuem(1,1),DATA,mtot
*cfopen,mass,txt,C:\Users\Desktop !Insert file path
*VWRITE,valuem(1,1)
(1X,F10.8)
*cfclose
Thank you for your help. It works,
Best regards,
Andrade Silva
