Azzazil
Automotive
- Feb 1, 2020
- 98
Hello all, when you calculate some force, moment or temperature how did you get sense on magnitude of your calculations what is big value and what is not?
Example 1) (Torque value)
I have M6 screw and I defined tightening torque to be 20Nm how to know if this value is OK or not if I did some mistake on my calculation, and how to visualize which value of torque is too big and which is small?
Example 2) (Heat/Temperature)
If I get on calculation that I will have some mechanical element that will be heated during his work to 80°C will you be able to touch it by hand or you will get burn.
Example 3) (Force)
I have 2 plastic parts which are joined by cantilever snap fit connection, assembly force is 50N. How to know if this is too big or not if I never assemble two halves of plastic parts to join them?
Basically my question is, are there some methods that you can get theoretically sense of magnitude you get by calculation or all of them I need test empirically?
Example 3) (Force)
