How To Limit Macro To Currently Opened Product
jzecha
Aerospace
I have a Macro that saves the Products/Parts as their in session part number.
It works great except if I have two products open it switches windows and saves both of them.
How do I modify this Macro to only work on the current open product and keep it from switching to the next open document?
Code:
Sub CATMain()
Dim noSymPartName As String
Dim noSymProductName As String
Dim newCharacter As String
newCharacter = "_"
CATIA.DisplayFileAlerts = False
Set oDocs = CATIA.Documents
docPath = oDocs.Item(1).Path
changePath = MsgBox("Current save location is: " & docPath & " Would you like to change file path?", vbYesNo)
If changePath = vbYes Then
Const WINDOW_HANDLE = 0
Const NO_OPTIONS = &H0001
'Const File_Path = "\\GTFS1\Share\Data\"
Const File_Path = 17
Set objShell = CreateObject("Shell.Application")
'Set objFolder = objShell.BrowseForFolder _
' (WINDOW_HANDLE, "Select a folder:", NO_OPTIONS, " \\GTFS1\Share\Data\")
(WINDOW_HANDLE, "Select a folder:", NO_OPTIONS, File_Path)
Set objFolderItem = objFolder.Self
'objPath = objFolderItem.Path
docPath = objFolderItem.Path
MsgBox docPath,,"Save Location"
'Set objFolderItem = CreateObject("Scripting.FileSystemObject")
'docPath = InputBox("Enter new file path", "File path")
End If
CATIA.RefreshDisplay = False
For x = 1 To oDocs.Count
If TypeName(oDocs.Item(x)) = "ProductDocument" Then
Set oDoc1 = oDocs.Item(x)
Set oProduct1 = oDoc1.Product
    noSymProductName = oProduct1.PartNumber 'get the current PartNumber
	noSymProductName = Replace(noSymProductName,".","")
	noSymProductName = Replace(noSymProductName,",","")
	noSymProductName = Replace(noSymProductName,"(","")
	noSymProductName = Replace(noSymProductName,")","")
	noSymProductName = Replace(noSymProductName,"/","")
	noSymProductName = Replace(noSymProductName,"\","")
	noSymProductName = Replace(noSymProductName,"#","")
	noSymProductName = Replace(noSymProductName,"$","")
	noSymProductName = Replace(noSymProductName,"%","")
	noSymProductName = Replace(noSymProductName,"*","")
oDoc1.SaveAs docPath & "\" & noSymProductName & ".CATProduct"
End If
Next 'x
For v = 1 To oDocs.Count
If TypeName(oDocs.Item(v)) = "PartDocument" Then
Set oDoc2 = oDocs.Item(v)
Set oPart1 = oDoc2.Product
    noSymPartName = oPart1.PartNumber 'get the current PartNumber
	noSymPartName = Replace(noSymPartName,".","")
	noSymPartName = Replace(noSymPartName,",","")
	noSymPartName = Replace(noSymPartName,"(","")
	noSymPartName = Replace(noSymPartName,")","")
	noSymPartName = Replace(noSymPartName,"/","")
	noSymPartName = Replace(noSymPartName,"\","")
	noSymPartName = Replace(noSymPartName,"#","")
	noSymPartName = Replace(noSymPartName,"$","")
	noSymPartName = Replace(noSymPartName,"%","")
	noSymPartName = Replace(noSymPartName,"*","")
oDoc2.SaveAs docPath & "\" & noSymPartName & ".CATPart"
On Error Resume Next
End If
Next 'v
CATIA.RefreshDisplay = True
Msgbox "Save Finished!",,"SAVE FINISH!"
Msgbox "YOU HAVE TO USE SAVE MANAGEMENT NOW!",,"YOU HAVE TO USE SAVE MANAGEMENT NOW!"
End Sub
it's because you are asking for ALL document loaded in CATIA session:
CATIA.ActiveDocument is the currently shown Product/Part...
so you'd need to loop thru your structure and get the correct document out.
regards,
LWolf
