How to properly show compound angles of a feature using GD&T?
Gaganaut06
Aerospace
IN
I have a drawing of a fitting which connects to a tube at a compound angle of 30deg and 45deg. Is this the correct way to show this (attached)
The views are fine, but the angularity tolerance is ambiguous as it is not clear which feature it applies to - is it the OD or the ID of the tube?
You should attach the angularity tolerance to the relevant size (diameter) dimension, and if you would use a single angularity tolerance, in view A only with a diameter symbol, you could create a single cylindrical tolerance zone for the axis that would control the compund angle instead of having two different requirements for the same axis (each time limited by a different parallel-planes tolerance zone).
To establish an angle one needs references. You have only the reference to [A], so you need one more reference to control clocking relative to whatever is important. You have suitable dimensions, just no references defined for tolerance for clocking.
Hi, Azeemsha:
As 3DDave indicated, you can't have a dangling BASIC dimension (30 degrees in this case). BASIC dimensions must be traced back to its datum feature(s). You can only use a dangling dimension if it is a size dimension for feature of size.
Happy New Year!
Alex
Thank you, jassco, 3DDave, Burunduk, for your clarifications. I have attached the updated drawing. Hope this is correct.
Happy New Year
Hi, Azeemsha:
The print looks Ok as long as you know that this feature with dimension dia. 17 is not located. You will also need a size tolerance for this dimension.
Best regards,
Alex
Hi, Azeemsha:
Best regards,
Alex
Is it wrong to assume that OP is expecting standard-size tubing whose diameter won't really be controlled by the manufacturer of this part?
Hi, Flying Whale:
Those 30 and 45 degrees BSC angles only control orientation. They do not locate the feature.
Best regards,
Alex
Hi, Flying Whale:
Best regards,
Alex
I see now that you were talking about the location of the part, I misunderstood it as if you were saying the 17mm diameter dimension needed tolerance.
It is not location of the part. I meant relocation of the cylindric feature in the part.
Best regards,
Alex
