how to reread ANSYS APDL commands upon each ANSYS WB static module project execution
andradesilva
Materials
Jun 20, 2017
125
I am doing a simulation in ANSYS Worbench 18.1 I am using the static module. The simulation is fine. However, I add two APDL command objects, one on the preprocessing and another on the post-processing. The problem is that if I change the variable values on the .txt APDL command files (which I imported into ANSYS WB) after running the project the first time, the results are not updated. Therefore, I only got correct results upon the first project solution
I would like to know how can I reread ANSYS APDL commands upon each ANSYS WB project execution. I tried to clear data from setup with a macro (journal file), but that did not work out.
Any suggestions are appreciated,
Thanks in advance,
Best wishes,
AndradeSilva
