klecm
- Aug 31, 2021
- 1
Hi All - I'm having to retrofit an existing expansion joint - was hoping to add a series of steel corbels below for support. Trouble is, corbels would be attached to a pretty serious PT beam. I contacted an x-ray sub to scan the beam - they informed me that they are unable to perform the work as it is too wide (4'-0"). They can only scan up sections up to 30" deep. Is this typical? Apparently they apply the film on one side of the beam, and the machine on the other face and they can only be 30" apart max. This is my first time setting up x-ray personally so I'm not sure if I should try to find a sub with a more powerful machine. Thanks!
