haynewp
- Dec 13, 2000
- 2,319
I have a case where due to very tight arch ceiling and wall interferences I can't install a gusset into the web to reach out and catch an HSS brace connecting to a WF column. The gusset would have to stick out too far from the column web for me to get the required welds to the HSS. Therefore, I am looking at connecting the HSS brace directly to the web and welding all around the HSS.
Would there appear to be enough room for weld accessibility in the attached case of welding directly to the column web? I am thinking of them accessing from the underside to get the needed welds on the sides of the HSS. The top side may be a little more difficult.
[URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1614358028/tips/HSS_KNEE_BRACE_TO_WEB_mmgxuo.pdf[/url]
