EngrRC
- Dec 19, 2018
- 51
Does anyone know of any guidance relating to moment connection between two hollow steel section beams, one beam (smaller tube) snug fit inside the other (bigger tube) by some contact length?
I imagine that bolts, when used to connect the two, would only resist axial loads to prevent them from separating. Or would the bolts resist some moment due to unavoidable fabrication tolerances, i.e. snug fit in only localized areas within the contact length?
