mastergate
Bonjour
We have an HV Neutral directly grounded using an insulated cable and a disconnecting switch (normally close).
The question is regarding the insulation level of this grounding material (cable+switch) per IEC standards?
should it be phase voltage 60kV (72,5) or 60kV/sqrt(3) or an LV cable is sufficient.
Thanks for your support
