skimboard20
- Mar 10, 2021
- 20
Hi all,
I'm working on a project where a contractor needs to drill holes in a few plywood shearwall bottom plates in order to run HVAC ducts. The bottom plate is 2x6, and the required penetration is about 5", so we can assume the bottom plate is essentially gone for about 12" of shearwall length (less than one stud bay). The bottom plate is nailed to joist blocking, with anther shearwall stacked directly below.
How big of an issue is this? My initial thought is that we are losing the bottom plate nailing along the length of the penetration. But I can figure out a way to get a few more nails into the bottom plate either side of the penetration. Are there any other considerations I need to address?
Thanks for the help!
