Krausen
- Jan 1, 2013
- 270
Curious for those with any experience with High Velocity Thermal Spray (HVTS) of high alloys inside VIII-1 pressure vessels for corrosion resistance ... would the application of this (typically only 20 mils thick of Hastelloy C276, or similar corrosion-resistant alloy, as I understand) allow you to consider your vessel as a "clad vessel" now under VIII-1? In other words, is this HVTS material considered "integrally bonded" to the base metal like traditional roll-bond or explosion-bond cladding is?
