232gulfstream
Guys,
I am laying out a radiant floor system for a fleet maintenance garage in a new building. The garage only has 1 exterior wall and roof and minor glass. It is 6200 sq. ft. The room is very well insulated and I am coming up with a calculated heat loss of about 25,000 BTU/HR. This number is purely sensible losses as my ventilation air is taken care of by roof top make-up air units and I will be delivering neutral air to the space. Im thinking I should probably bump this number up quiet a bit just to make sure I have ample heat (i.e. the old 25-40 btu/hr per sq. ft. so I know I enough heat. Once the slab gets warm there will be a lot of mass there but I am worried about the doors constantly opening and closing that could effect room comfort. Bear with me as I don't do a lot of radiant floor heat designs.
Thanks!
Gary
Thanks!
Gary
