SHD_
Chemical
- Feb 10, 2020
- 5
Hi!
I'm currently in the process of designing a heat exchanger (as part of a large process). I know the desired inlet and outlet temperatures and the flow rates. Ethylene gas are the both streams being heated/cooled.
I am struggling to understand the difference between Q=m.c.dT and Q=U.A.dT and what cp values to use when (as I'm aware that cp values of gas will change with temperature).
Thank you in advance for your time
