HY8 Won't Run
Teresa2006
Hello, I was wondering if anyone could help me figure out why this program won't work for me? After entering the information into HY8 InpGen and clicking on Save/Calculate, I get an error message:
"Path not found in module BALANCE at address 0946:2CEF"
I've tried redownloading the program, and that hasn't solved the problem.
Thank you
I cant remember if that was my exact probelm, but I had to move hy HY8 v6.1 to my root directory to get it to work properly.
make sure you use 8 characters or less for the directory
I've been at this job for 1.5 years, and have just (out of curiousity) tried the HY8 here, or any DOS based program.
I got "Path not found in line 380 of module CULVERT at address 1D2B:76D3". I don't have Admin permissions to move it to C. My personal folder on C has more than 8 characters. I don't have Admin permissions to rename it.
Oh well, I guess no DOS stuff for me.
Engineering is the practice of the art of science - Steve
Thanks for your responses,
The directory it was in was in C:\WMS71\HY8. I moved it to C:\HY8, and that didn't solve anything. Do all the file names have to be under 8 as well? I'm running HY8InpGen.exe, but that's how it came named, so I don't think thats the issue.
I have HY8v6 in its own directory on C:\. I have a DOS shortcut witht the PROGRAM tab configured to define the specific path to the command line and the working directory (C:\HY8V6\). And to close the window upon exit.
It has been a while since I set it up, but I also recall needing to run the SETUP program first.
