Hydraulic cropping machine blade materail
Andy Lacey
Industrial
Aug 6, 2018
1
Good Afternoon All
I have designed and manufactured a cropping machine for cutting titanium fixings up to a Ø of 8mm (see attached PDF)
Unfortunately I am having difficulty in selecting a material that will last longer than a week for the blades (item 14) We are currently on the 4th iteration and using an M42 high speed steel hardened to 65-70 HRC. they last very well for a few days with no signs of wear or damage and then all of a sudden they chip.
I am hoping there is someone out there who could recommend a better material or at least a hardening process to make them last longer.
Many thanks
Andy
 https://files.engineering.com/getfile.aspx?folder=6f0ee0c5-3efc-40ea-ba50-30e996d9df18&file=10631-003-A01_(PRESS_ASSEMBLY)_Sheet_2-RevF.pdf
