We have a 30” buried HDPE water pipeline designed and built as per CSA Z662. Due to space limitations and non-availability of long radius elbows, we are using standard 1.5D fittings. The pipeline runs about 2 Km outside and 2 Km inside the plant. This line shall be constructed at different times in sections by different contractors. Each contractor shall be testing their scope and capping it off and then there will be one final test after all the tie ins. (This (final test)has not been finalized yet and still has room for optimization)
How can we ensure that all the air has been pushed out from the system for each individual section and from the entire length during the final test? Due to shorter radius 1.5D fittings we cannot run foam pigs. If we use vents at high points, we shall have to either bury the valves in vents or bring them A/G. If we bury those it will be flanged buried connection which we want to avoid. If we bring it A/G, we might need insulation and heat tracing for HDPE which is not easy. Our design temp is 22C.
Any ideas how we can get the air out, and what if the air stays in, to some extent. I am not expecting a huge amount of air as profile does not show lots of pockets.
Any ideas from someone who worked on HDPE hydro testing water line in Oil and Gas field. The pipeline is in BC.
