Hydrocad Exfiltration Invert Elevation
meatymatt
11
Using hydrocad version 8
For a pond with a pervious bottom I have always clicked "allow exfiltration at all elevations"
By default, hydrocad 8 sets the invert elevation to 0
It seems like newer versions of hydrocad have a different screen and when selecting "allow exfiltration at all elevations" it assigns the invert at the bottom of the pond vs "0"?
On a recent stormwater report, the reviewer has requested that I set the invert for exfiltration at the bottom of the pond
When I do this, I get 0 exfiltration since I am only allowing on horizontal plane and hydrocad now assumes the bottom is impervious
Your thoughts?
Thank you
An exfiltration invert of zero with HydroCAD 8 is equivalent to "Allow exfiltration at all elevations" on later versions. Later versions will then report a zero invert. They do NOT set the pond bottom elevation.
