Hi
I would like to ask for hydrodynamic bearings,
1. Is forced lubrication system always required?
2. If not mandatory, is there any requirement(s) in code and standard addressing when forced lubrication system is required for bearings?
3. If no requirement from code and standard, why are typical factors considered by equipment/bearing manufacturer when forced lubrication system should be used?
Thank you.
Thank you.
