I just need some help i can perform hydrotest i did it before the only problem is we don't have a test manifold here.
Our piping is Grooved system and according to NFPA Code the system should be tested not less the 13.8 bar our design pressure is 10 Bar.
For the manifold i want just a simple design with material to be used for example class 300 or 600 Ball valve ..etc.
max pressure of the manifold is 60 Bar.
