Arshad Ahamed
- Jul 31, 2018
- 23
Hi all,
We have used 20" 8.5mm THK API 5L X65 PSL2 Pipe for Skin Effect Heat Traced Pipeline (pipeline beyond refinery walls, and ASTM A106 Gr.B XS 20" piping inside the refinery). The design pressure of the pipeline is 45kg/cm2.
Inside the refinery, the hydrotest was done at a pressure of 67.5 kg/cm2 (1.5 times the design), while outside (corridor piping), the hydotest was done at a pressure of 131 kg/cm2. I was told that the 90% SMYS Criteria was adopted here.
Could someone clarify this and tell me exactly how the calculations come into effect? At what pressure will the specified hoop stress corresponding to 90% SMYS be generated.
P.S : I'm in my 7th month in this industry
, so kindly bombard all your ideas and thoughts here. I'm looking at a huge learning opportunity!
Thanks and Regards.
![[glasses] [glasses] [glasses]](/data/assets/smilies/glasses.gif)
Thanks and Regards.
