Hydrotest prior of NDT and PWHT
Eduardo1982
CL
Hey guys I hope ervtybody here is fine.
I wish to know yuor ideas in regards of the next topic. As it is stipulated in several docs and codes PWHT and NDT must be done before of any test pressure on lines. In many systems, like steam lines to turbines or boilers, the chemical cleaning and steam blowing Will be done after test pressure. However, as normal practises, some valves are installed after chemical cleaning & steam blowing process and welding Works (with NDT & PWHT) must be performed as "Golden joints". The point is that.. what could be the risk if instead to perform NDT & PWHT on time before of hydrotest, I decide to perform some PWHT & NDT after chemical cleaning? If I believe that my welders are skyll enough so probably I won´t have any problem with the soundness of the welds…. or is there any problem related to mechanical properties on the pipe that I could see only with hydrotest?
A golden joint is with a exception to hydrotest.. so for the specific valve joints identified already as golden joints, what you intend to propose is already being done.. need more elaboration in your question if I couldn't get it right.
If you are the owner, why bother for a hydro-test?
Unless you are not the owner....
DHURJATI SEN
Kolkata, India
IMO you should perform NDT & PWHT on time before of hydrotest. After all welding is complected than you steam blow and chemical clean if it is a boiler than you finally make the hidrotest with demi water.
luis
