Greetings!
1)Seeking for guidance from experts about hydrotest requirements for atm line.
2)Can we reduce the hydrotest pressure requirement of process line given in B31.3 below 1.5 in any case? Someone sent me this
(When performing a hydrostatic test on a piping system, it is important to ensure that the test pressure does not exceed the pressure rating of the piping system or the pressure-retaining components. The pressure rating of a piping system is the maximum pressure that the system is designed to safely contain. The pressure rating of a pressure-retaining component, such as a valve or flange, is the maximum pressure that the component is designed to withstand.
If the hydrostatic test pressure exceeds the pressure rating of the piping system or a pressure-retaining component, there is a risk of over-pressurization, which can result in damage or failure of the system. Over-pressurization can cause deformation, cracking, or even rupturing of the piping system, leading to leaks or even catastrophic failure. Therefore, to ensure the safety and integrity of the piping system, it is crucial to carefully monitor the test pressure and to ensure that it does not exceed the pressure rating of the system or its components)
and saying 1.5 is not mandatory but I think code sticks to 1.5 times.
