bbac
Geotechnical
- Feb 28, 2019
- 5
I am designing MSEW wall. The wall has slope of 6 degrees with vertical and it has 20m height, and a 2m wide berm at 10m depth. I am checking External stability, Global stability and internal stability. I use a slope stability program for checking global stability. Is it sufficient to use slope stability program also for checking internal stability (rupture and pullout)? Or do we need to verify rupture and pullout resistance for each layer by hand calculation, assuming a failure plane eg. coulomb`s active earth pressure case)?
