I have an error message in the expression: "New expression variable name is invalid"
Bogdan1985
72
I use NX8.0 and design a plastic part with expression draft. The error message
shows up: "New expression variable name is invalid"
How can I repair this?
Thx
What is the name of the expression?
John R. Baker, P.E. (ret)
EX-Product 'Evangelist'
Irvine, CA
Siemens PLM:
UG/NX Museum:
Thanks John, the problem was solved next day. The reason was, that I used underscores "_" .So I understood
in newer versions of NX is this possible.
An underscore should be OK, at least I thought it was when I was still using NX (2+ years ago).
Irvine, CA
Siemens PLM:
UG/NX Museum:
underscore is invalid as the first
character of an expression name.
Yes, that would be true, but as an embedded character, it should work.
Irvine, CA
Siemens PLM:
UG/NX Museum:
