I marker is not associated with geometry - NX 12.0.1 // NX Motion
mathisudar2007
Automotive
Aug 1, 2012
100
thread561-439539
During Model Check , getting below warning
base_to_balance_link Warning: I marker is not associated with geometry
base_to_balance_link Warning: J marker is not associated with geometry
can be solved by following the below procedure.
// From NX Doc
The I marker (action link) or J marker (base link) is not associative. For example, this warning may appear if you defined an orientation by specifying a fixed vector rather than inferring it from geometry. If you move the component in the master model, the joint will not be updated in the Motion simulation.
regards,
Mathi Krishnan
NX12.0.1.7
