ICPR Boundary Outflow Question
Jeff Raykos
I'm working on an FDOT ICPR analysis for a commercial property We have to run a low starting tailwater elevation for max. flow and a high starting tailwater elevation for max. flood. For the low condition at the Boundary node I get a Max. Total Inflow of 12.45 CFS and a Max. Total Outflow of 0.0 CFS, which makes sense. However when I only change the starting tailwater elevation at the Boundary node to the top of the pipe instead of the invert, a change of 2.5', I then get a Max. Total Inflow of 12.23 CFS but a Max. Total Outflow of 28.40 CFS. Can anyone explain what the Total Outflow at the Boundary node represents and why this value jumps so high? Thanks.
How is the tailwater defined at the boundary node? Is the stage defined for the Time/Stage node for the full duration of the storm event or just the initial time?
