Guest
I have a 94 Transport with a major problem of the idle swinging so bad the engine dies. I have taken it to 3 repair shops and none can fix it. It only does it when cold, after the engine gets past 160' it runs great. New parts include egr valve, idle air motor, o2 sensor, plugs and wires, coolent temp sensor, cam sensor, crank sensor and
upper intake gasket. Any ideas would help. Thanks
