NickParker
- Sep 1, 2017
- 446
Where can I find out the actual X/R ratio in ETAP? to compared it with the tested ratio of X/R=14?
What should be done if the actual X/R ratio is greater than that of tester X/R ratio (14)? I know that in ANSI, the breaker to be derated by the multiplying factor. Is there any multiplier in IEC 60909?
