NickParker
Which fault current to be considered for ground grid calculation at the substation with respect to step and touch potential?
a) L-G fault at HV voltage of HV/MV transformer (fault at the HV side of the transformer - source side from Grid)
b) L-G fault at MV voltage of HV/MV transformer (fault at the MV side of the transformer - at the load side)
b) L-G fault at LV voltage of MV/LV transformer (fault at the LV side of the MV/LV transformer - this is the distribution transformer at the same substation as a & b)
