flyforever85
New member
I'm not practical with SolidWorks but I need an IGES file from Solidworks to import into ABAQUS. The component is made of 2 extruded part (which in the iges appear as solid) and several pipes (which they appear has inner and outer faces but no solid). The pipes were generated but their axis with a certain diameter and thickness.
Is there a way to create a whole solid instead of a mix of solid and surfaces?
Thank you
Thank you
