IIF Function 1
mkmech
CA
I have seen this IIF function being mentioned in this forum several times. Can someone tell me what it is? I have never used it before. I couldn't find it in Help.
The following has been pasted from Visual Basic help file...
IIf Function
Returns one of two parts, depending on the evaluation of an expression.
Syntax
IIf(expr, truepart, falsepart)
The IIf function syntax has these named arguments:
expr Required. Expression you want to evaluate.
truepart Required. Value or expression returned if expr is True.
falsepart Required. Value or expression returned if expr is False.
Remarks
IIf always evaluates both truepart and falsepart, even though it returns only one of them. Because of this, you should watch for undesirable side effects. For example, if evaluating falsepart results in a division by zero error, an error occurs even if expr is True.
[bat]I could be the world's greatest underachiever, if I could just learn to apply myself.[bat]
-SolidWorks API VB programming help
Thanks TheTick. I have never used VB in SW. I am assuming this can be applied to perform certain actions in SW. Can you give me some simple example? Where can I find more detailed info on this kind of stuff/functions and their application in SW?
VB can be readily applied to SolidWorks. SW macros are written/recorden in VBA (a specialized VB). You can access nearly all of VB's functionality via VB and also C++. Word has it JAVA works, too, but there is no documentation to help JAVA programmers.
The iif function is an example of some programmatic spillover from the inner workings of SW being available as an "undocumented feature".
It's used in the Equation function.
Jason Capriotti
Smith & Nephew, Inc.
