I'm going to lose my mind. how d 6
flitch1969
Automotive
how do you turn off or keep away the small box that appears in some operatators like 'clip section'
this small box appears right where my cursor is and it follows it around. RRRRRRRRR!!!!!
i hope someone can help. i attached a picture.
 https://files.engineering.com/getfile.aspx?folder=ab4fc6ef-cfd0-45b8-92cc-bb16fd8a56ad&file=this.JPG
As far as I am concerned it should default to OFF and then press F3 if you want it ON. It is really a pain.
Jerry J.
UGV5-NX11
This F3 only works if you don't have the Great F1-f4 keys Variable turned ON for us ancient I-Deas users.
UGII_FKEY_DYNAMICS = 1
Go To "Tools > Customize > Keyboard" to remap the UG_VIEW_CURRENT_DIALOG command to map a new shortcut key to turn this off.
Also please see thread above.
