I'm trying to improve myself in vba and macro. Tell me ideas and I will try to make :)
Dialga1
15
I will wait your ideas for macros.
Product structure and part parameters export to excel with customizable query conditions, attribute mapping, column grouping etc.
another one: get XYZ of points form part, even if the part is in product, in this case provide both global and local XYZ.
Then go from XYZ in excel to points in part...
Eric N.
Hi! I take this opportunity to ask you help about something i'm struggling for.
I'm trying to write a macro that measures some lines and write the output in a csv file.
These lines are called "feet-line", and are objects of some (not all) catparts inside the active catproduct.
take a data set, time vs Force,
24 hours worth and select and plot every 100th point. You'll have to make up the data set.
You'll encounter this in engineering testing quite a few times.
