sizzer33
- Jan 6, 2008
- 32
- 0
- 0
Hi all,
Just wondering if anyone can point me to the right direction in solving this IML issue.
Here are the info:-
- IML foil is PET 0.75mm
- Part to be IML is PC material.
- Mould temp during test, 45-55degC
- Part is a mobile phone front window. It is a rectangular part with only slight curve, transparent PC with IML foil to make a significant pattern and small opening for the front LCD. ITs very common on flip phones.
Problem:-
- Molded parts fail several test such as vibration abrasion test, temperature test, salt mist test.
- What happen is for example in salt mist test, the IML foil would peel off.
- Also, when the test fail, it would only occur randomly such as 2 or 3 fail parts out of 5.
Question:-
- does mould release agent affect IML foil adhesive properties. During mould test, we sprayed some mould release agent on cavity side during start of moulding.
- how bout the mould temperature affect on the IML foil adhesive properties?
Any advise is welcome. thanks
Here are the info:-
Problem:-
Question:-
